Welcome Guest - Sign Up today
No announcement yet.
Power tilt and trim solenoid
  • Power tilt and trim solenoid
    Im putting a used trim pump in my boat and i believe the solenoid that came with it is either bad or its the wrong one for this pump. I can get the pump to run one direction if i wire it through the solenoid and when i hardwired it i got it to run both directions. I pulled the solenoid off and I noticed its made by motorcraft (ford) and looks identical to the starter solenoid on the engine (ford 351w). Will another ford starter solenoid work? Is there any difference between a starter solenoid and a trim pump solenoid? Thanks
    Re: Power tilt and trim solenoid
    Been there done that... I also used an auto (Ford) solenoid. Worked for several years until I sold my boat.
    I guess they are not marine grade and technically not allowed as per the coasties, but they do work well.
