Welcome Guest - Sign Up today
No announcement yet.
Detroit diesel engines
  • Detroit diesel engines
    I have a 1976 6v53 detroit diesel inboard that has not been started in 11 years.
    engine is not seized up and was winterized at that time.what precautions should
    be done before trying to start engine.also what weight engine oil should be used,
    and what type of antifreeze should i use in cooling system.
    thanks for any information anyone can provide.
    jennyo
    I would suggest using heavy duty ELC antifreeze. Need low silicate type by DD, Fleet Guard or NAPA, that is pre charged with SCA (Supplemental Coolant Additive)
    Oil 15W40 Diesel oil
    If you have to remove the air filter to where its a smooth round opening, and have a board or plate the size of the hole. The board can be used to kill the motor if it starts to run away at high rpm and the throttle will not control it. If it does this, slap the board/plate over the intake and the motor will die.
    It probably won't do this but this is just incase
    94 Formula 27PC Custom 509MPI MEFI3 , B3 XR
    95 Rinker 232 w/ 7.4L Carb 0F425011 B1 0F486471
    07 Seadoo GTX
    Merc Adults Only VP Adults Only
    G-Dad always said "First Liar doesn't stand a chance"
    • #3
      thank you for that quick reply.i will let you know
      when i get it running.
      Thanks
      jennyo
