Welcome Guest - Sign Up today
No announcement yet.
engine stalls and tach stops working
  • engine stalls and tach stops working
    So i`m a newbie here and a novice when it comes to engine repair so forgive me if my terminology is off that being said i have a 1994 175 Evinrude EXERV its a fairly new rebuild with about 200 hours on it . The issues i`m having and i`m not sure if they are related or not .One the motor idles somewhat rough800-1000 rpm (it revs up Fine with no loss of tach ) when connected to the flush ears , However when i put it in the water is sputters and barely idles, spits and stalls when i try to accelerate , now once i manage to get it up and running over 1500 rpm it runs great. However around the same time at around 1500 rpm the tach stops working when i throttle back down the tach kicks back in and it begins to run like crap again any help on the subject would be greatly appreciated ( the fuel pump was replaced and it still does the same thing I might addd)
