Welcome Guest - Sign Up today
No announcement yet.
question on manual release valve
  • question on manual release valve
    i have suzuki df 70 2007,and on manual release valve i have oil leak,so when i tilt up,refill oil and than all way down i see trough MRV hole oil almost spraying out,what is worse than that is that i have manual release valve screw stripped completly by previous owner,what and how to proceed with repair
    Re: question on manual release valve
    how to extract the broken valve,can it be done by disassembling the pump from other side or should i just weld the leaking hole,please help
    • #3
      or what to do?
      • #4
        help,anybody
        • #5
          somebody?
          • #6
            Nobody...
            • #7
              please
              • #8
                well with out much help here so far,
                your best bet would be to get a service manual for your motor to see if it has a procedure to do it
                • #9
                  i wonder if i put liquid steel would it keep oil in,and prevent leaking
                  • #10
                    or weld it
